-   -   Background fluid (http://www.cfd-online.com/Forums/cfx/20358-background-fluid.html)
Andrea May 12, 2004 06:56
Background fluid
Is possible set two different background fluid in the same simulation but in two different isolated block?
Thanks in advance
Andrea
test May 12, 2004 07:57
Re: Background fluid
If you are using CFX-5.6 you have to use a workaround. In CFX-5.7 you can create different domains with different fluid and different models too!
In CFX-5.6, define a multi-component mixture of the two fluid u want to define.
Use this multi-component fluid for both the domains. Only things u need to take care is boundary and initial conidition.
Use a step or subdomain function to make sure that particluar domain contains only that fluid. IN the boundary conditions (mainly inlet) make sure u specify the mass fraction of 1 for the appropriate fluid.
Let me know if u need further assistance.
Andrea May 12, 2004 08:09
I'm a Cfx 4.4 user...
Andrea May 12, 2004 11:59
In Cfx 4.4 I think I must define a multicomponent mixture.
The problem is that in the two different domain I have two different mixture.
So can I set my multicomponent mixture and "separate" the fluid. But I need have two different group of properties (viscosity, Cp...) for the two background fluid. I must set this properties by user fortran?
Thanks
Andrea
