Pressure and velocity fluctuations
Old   May 23, 2004, 01:08
Default Pressure and velocity fluctuations
Jeff
Anyone know if it's possible to convert the turbulence quantities (k/eps or reynolds stresses) to a frequency distribution of pressures and velocities? That is, derive a PDF for pressure/velocity over a fluctuation frequency range?
Jeff
Old   May 23, 2004, 18:45
Default Re: Pressure and velocity fluctuations
Hi Jeff,
I'm no turbulence guru, but to my knowledge both of these turbulence models can only give you elementary information about the turbulence spectrum, such as the turbulence length and time scales. The kolmogorov time and length scales can also be worked out. That's about all you can get out of it.
Regards, Glenn
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
