-   -   A question about .eps images using CFX5.6 post (http://www.cfd-online.com/Forums/cfx/20438-question-about-eps-images-using-cfx5-6-post.html)
Forrest June 15, 2004 07:42
Hi all,
I am trying to generate some colour images using CFX5.6 post and I suppose .eps is a very good format to get images with good qualities. The question is that the post generates the image together with the large background, which makes the file size quite large. When I insert the .eps iamge into other document (e.g. word) I have to scale or/and crop it in order to fit with text. Is there any way to set up the output of the image, say the image size, or the background size? Sometimes I don't need the images showing the axes then I get rid of it, but it seems no way to get rid of the bottom right logo, any idea? Thank you for your help
Regards Forrest
Michael Bo June 16, 2004 02:23
Re: A question about .eps images using CFX5.6 post
When including pictures into MS Word I use PNG files for an optimum between quality and file size. EPS/PS is a better quality but PNG's are very small in file size. Also PNG's can easily be edited using a standard picture editing program.
Forrest June 16, 2004 04:54
Thank you Michael for your advice, yeah, you are right, png files work quite ok for colour image in word. Only bit fuzzy for vectors and mesh. I will use it as an alternative, especially for thesis writing, file size can be a problem.
Regards, Forrest
Michael Bo June 16, 2004 06:40
You could increase the pixel size to reduce the fuzzy vectors in a vector plot. Try increasing the size to 1263*1024 pixels (1,3 Mega) or even higher 1579*1280 pixel = 2 Megapixels.
Forrest June 17, 2004 04:52
Thank you Michael, Increasing the resolution does help! Cheers, Forrest.
Jeff June 17, 2004 22:39
Forrest,
Once you get the png image into Word or Powerpoint, go to picture properties (format image?) and you can crop the edges in to get rid of any axis or logos that you don't want. Of course you can just disable the axis under edit|options, but the logo is hard coded. Just make sure your model image is just inside the rectangle you'll be cropping to.
Jeff
Forrest June 18, 2004 03:24
Thank you Jeff, I did use 'crop' a lot in word for these images generated using CFX5.6 post.
All the best, Forrest
