-   -   I have a Problem with Flotran (http://www.cfd-online.com/Forums/cfx/20440-i-have-problem-flotran.html)
Ashok June 16, 2004 09:26
When i run a flotran analysis i get an error stating
Error attempting to backup unuseable results file check READ/WRITE permission . file.rfo
so what should i do to rectify this problem
and even if it runs the analysis i gives a strange error in the middle of the run stating
cannot able to retrieve flotran data object
any help regarding the problem would be appreciated
thanks in advance
derrek June 16, 2004 20:55
Re: I have a Problem with Flotran
this looks like a read/write permissions issue on your system. FLOTRAN will attempt to backup your results file as an *.rfo file, if you change something liek the mesh density etc.. Could this explain what you are seeing?
cheers,
derrek
