Physical properties about "Air Ideal Gas" In CFX |
July 8, 2004, 22:42 |
I am doing numerical simulation about the mixing of two fluids with different temperature by CFX-5. Both of the fluids were set to "Air Ideal Gas" with the higher temperature of 300k and the lower temperature of 150 (pressure 1 atm). But I got the averaged density at the high temperature(300K) inlet the value of 2.34kg/m^3, which should be 1.2kg/m^3 dut to the temperature and pressure. Can anybody tell me the possible reason? I am a new user of CFX.
July 9, 2004, 01:28 |
Re: Physical properties about "Air Ideal Gas" In C
It seems to be like you have temperature close to 150K at inlet(density 2.3528228852054585 kg/m^3)... Check your physics. Or describe your model more precisely(or send it if it is small).
July 10, 2004, 03:22 |
Thanks, deLuther
This is my first time to use CFX (used to Fluent before), so maybe I have made some very stupid mistakes. The density at the low temperature 150K inlet is 4.33 refer to the area-averaged calculation, which is almost twice the ordinary value(similar thing happened at the 300K inlet). I just set desity to be calculated based on the ideal gas law. I'll check it more carefully. |
Display Modes | |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 03:20 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 06:59 |
physical properties used in CFD codes | Craig Branch | Main CFD Forum | 2 | September 28, 2004 04:35 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
