-   CFX (
-   -   "Periodic" boundary (
Stex July 12, 2004 07:18
"Periodic" boundary
Hi, I'm studying the flow inside a single pipe heat exchanger. I use CFX with the "Periodic" boundary. After trying some value of "momentum source" I find the right one to carry out the mass flow I need. But after all I found a value of the pressure equal both on the inlet and outlet. So how can I calculate the Pressure Drop? Thank you very much.
Derrek July 12, 2004 11:00
Re: "Periodic" boundary
Define an expression such as "deltaP" = massFlowAve(ptot)@thenameofyourinlet -massFlowAve(ptot)@thenameofyouroutlet.
Then in the Output Control. Define a monitor point and define it as an expression = deltaP..
When you go to Post, you will have an expression defined that automatically calculates your pressure drop..
Stevie Wonder July 13, 2004 09:26
If you have a periodic BC, your local pressure drop in the streamwise direction is:
If your periodic domain has 1m length, the pressure drop of 50m will be 50 * dp.
If you want to model pressure drop I think you should consider a domain with an inlet/outlet instead.
Good luck, Stevie Wonder
