Home > Forums > CFX
CFXsolver error
Old   July 14, 2004, 23:47
Default CFXsolver error
jemteo
Ive encountered the following error, any idea what is causing this?
A wall has been placed at portion(s) of an OUTLET boundary condition (at 74 % of the faces, 74 % of the area)to prevent fluid from flowing into the domain. The boundary condition name is: outlet. The fluid name is: Water at 25 C.If this situation persists, consider switching to an Opening type boundary condition instead.
Old   July 15, 2004, 00:24
Default Re: CFXsolver error
deLuther
This was caused by recirculation at outlet. If this hapens at begining it can fade away as solution converging. If no, use opening BC or move outlet further downstream. For openning BC you need to specify temperature which you can obtain by using expression (see tutorial CHT in heating coil for details).
Thread Tools
Trackbacks are On
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 02:40
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
