July 28, 2004, 11:17 |
CAD2Mesh query
Hi
We are working on a complex arterial geometry in the retina and we are stuck at the junctions. We constructed the three dimensional basic network of arteries using another CAD program and we could successfully import that into CAD2Mesh. However, we noticed that some solid bodies appeared as hollow surface bodies (mainly at the junctions of the arteries). We are unable to mesh the stuff and think that this might be due to those surface bodies. Could anyone suggest a way to get pass this problem? Are we right to think that it is these surface bodies that are causing the problem and if so, is it possible to convert them to solid bodies? Cheers, Prash |
July 29, 2004, 09:24 |
Re: CAD2Mesh query
Prash:
You can attempt to form solids (body operation) in Design Modeler. Solids are required for CFX MESH. However, if you have a license of ICEM through CAD2MESH, you can use TETRA to mesh the model. TETRA only requires bounding surfaces. Cheers, Derrek |
July 29, 2004, 09:35 |
Re: CAD2Mesh query
Many thanks, Derrek! We used ICEM to generate a tet-mesh that seems to work without probs with CFX-5.7.
Cheers, Prash |
August 1, 2004, 18:26 |
Re: CAD2Mesh query
i thought icem needs a cloded set of surfaces as well?
how to query node coordinates? | phsieh2005 | OpenFOAM Post-Processing | 3 | November 26, 2018 20:13 |
How to install CAD2Mesh? | Jason | CFX | 4 | July 12, 2004 10:58 |
CAD2Mesh geometry creation | hannah | CFX | 4 | May 17, 2004 12:17 |
CAD2mesh spacings | pi | CFX | 0 | May 14, 2004 14:31 |
CAD2Mesh infl. exp factor | bogesz | CFX | 2 | April 4, 2004 18:50 |
