problems with tight flow domain on object
hope someone can help me. i want to simulate the flow thru a tube which has an object inside of it. The tube tighly encloses the sides of the object making it not possible for flow to go thru the interface. I have problem making such a mesh I imported .IGS of my tube (diameter 30mm) from solid works into ICEM CFD and created a surface tet mesh of it. AFter which i import a .stl of my object (diameter 30mm) and position the object accordingly. i get this error ERR 3104 : EDGE 5154 5475 INTERSECTS WITH FACE 23 251 1122 ERROR:3104 - A surface edge intersects a surface face status 1 i tried merging the nodes at the interface but still get this error ERR 3103 : EDGE 13191 13219 INTERSECTS WITH EDGE 11443 2464 ERROR:3103 - Two edges intersect in surface mesh status 1 it can be meshed when i give an allowance say 30.005mm but it is not leakproof. can anyone advise me thanks. |
