August 9, 2004, 11:36 |
meshing strategy for tight fit.
Hi.
im using ICEM4CFD as a pre=processor. i'm trying to simulate the flow past a complex object. The object is tightly fitted into a tube. The complex object exsists as an .stl file and the tube a .igs file. i've imported the .stl file and did the segmentation of surfaces and curves, and also imported the tube. after aligning both objects to my desire, i've tried joinging the interfacing surfaces using merge surface tool. however, the mesh is undesirable. When creating a tube slightly larger than the object, meshing is not a problem and i can easily run a simulation. Can someone suggest a meshing strategy for tight fitting my object in question into the tube? thanks |
August 9, 2004, 18:50 |
Re: meshing strategy for tight fit.
We will need to see the mesh you are generating to be able to help you. Glenn |
August 10, 2004, 00:12 |
How do i show my mesh?
August 10, 2004, 01:56 |
You can create an account at www.pbase.com an upload your pictures there, and include the link to the picture in the postings. Like this: http://www.pbase.com/michaelbo/cfd - Michael Bo
August 10, 2004, 02:30 |
thanks mike here is my pic before any attempts on meshing http://www.pbase.com/image/32402615
green is the desired flow domain and grey is the complicated object imported as an .stl. i faced a lot of problems to get the interface of the object and domain to be a tight fit. i hope this helps |
3d meshing strategy for propeller in gambit | Harikrishna | FLUENT | 3 | January 12, 2012 06:38 |
Wing meshing strategy | lasherwc | Main CFD Forum | 0 | June 2, 2009 15:04 |
Meshing strategy for a tapered tube | Dave | FLUENT | 0 | January 4, 2006 13:20 |
Meshing Strategy... | Harmeet | CFX | 1 | July 9, 2004 00:32 |
block meshing strategy | J Reed | Siemens | 0 | March 7, 2000 11:41 |
