August 10, 2004, 22:42 |
4 No data source for workspace
Hi, CFX Users!
I Run CFX 5.6 and most of the times I get two subsequent messages at the beginning: from the solver: "No data source for workspace, cannot monitor Solver data." Could anybody tell me where do I make my *.def file corrupted or what? Greg |
January 3, 2015, 03:39 |
Rep Power: 11 |
Hi, bit of a thread revival! But does anyone know what this error means, and better yet, how to fix it?
Cheers |
January 3, 2015, 04:38 |
Rep Power: 143 |
I have never seen that error before. Are you sure your CFX installation is OK? Do the tutorial examples run OK? What are you modelling?
January 3, 2015, 05:23 |
Rep Power: 11 |
I will double check. I have only started to come across it just before Xmas. Attempting to model a complete car (simplified). I have done it before with a very similar model (the wings in different positions etc) with no issues. It does appear to solve the simulation, but whilst running I don't get any outputs such as the graphs or text info, but I do get data that will run in CFD Post that looks sensible. I will go back to some previously working models and see if they still work!
January 3, 2015, 05:37 |
Rep Power: 143 |
It looks like a Solver Manager error, not a solver error. Solver Manager only views and controls the simulation in progress, it is not the solver itself. So your solver is probably running fine.
The error probably means it is looking for a running simulation directory and cannot find one. Check that a run is in progress, and that the correct directory is chosen. CFX runs in a temporary directory called .cfx_tmpdir when it is running. This directory is deleted when a run completes, and all the results file stuff is transferred to the final location. |
January 3, 2015, 08:50 |
Rep Power: 11 |
I will have a look at this, cheers. I am now carrying out a re-run of an earlier test and all seems to be OK though. When it is finished I will retry the troublesome one!
January 3, 2015, 10:58 |
Rep Power: 11 |
Hmm, seems to have been peculiar to that specific setup. New setups are running as are the other pre-existing ones. But for whatever reason that setup gives me errors. I have tried to recreate it all from scratch and I still get the error... Anyway, thanks for the help and advice
January 28, 2016, 02:57 |
Soolmaz
I get the same error also. In my case, I'm trying to restart a FSI simulation. Does any one have any suggestion? I used the prev cfx res file both as the input file and initial condition. I attached how I did the setup for the mechanical side as a restart also. Thanks in advance /Solmaz |
momentum source, fan curve data | nag | CFX | 0 | July 28, 2010 10:30 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
