Mixing-Plane-Method in CFX
Old   August 17, 2004, 06:53
Default Mixing-Plane-Method in CFX
wang
Could someone tell me wether CFX5 can simulate axial compressor with Mixing-Plane-Method? With which turbulence model?
Thanks
Old   August 17, 2004, 11:47
Default Re: Mixing-Plane-Method in CFX
Robin
Hi Wang,
The Stage (mixing-plane) interface model will do what you are requesting. It is fully conservative and compatible with all turbulence models, including Laminar, Zero Equation, k epsilon, RNG k epsilon, k omega, SST, DES SST, Reynolds Stress, SSG Reynolds Stress, QI Reynolds Stress, BSL Reynolds Stress, and more...
Regards, Robin
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Is Particle Finite Element Method applied in CFX? WenZyn Lim CFX 0 April 6, 2011 11:47
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 09:16
MFR and mixing plane boundary . Mica FLUENT 0 January 26, 2007 09:39
difference in MRF and Mixing plane sam FLUENT 0 November 18, 2006 11:34
