about the streamlines
Old   August 18, 2004, 05:34
Default about the streamlines
lingo
Hi,everyone: I met a problem about streamlines: When I choose the inlet as location,I get a group of streamlines.I also found that every streamline begin with the nodes of inlet. I need to do something on every streamline coming from the inlet.However ,the streamlines are in group,so I cann't solve my problem.I don't know how to set up a streamline which comes from a node of inlet. Could you give me any suggestions?
Regards lingo
Old   August 18, 2004, 05:58
Default Re: about the streamlines
lingo
Hi,friends:
I think through "Create\Streamline\ Locations:Point "could set up a streamline for each node of inlet.But I don't know the exact x,y,z value of each node or node number.
Old   August 18, 2004, 18:25
Just use your inlet as the locator. It will then use each node in the inlet to start a streamline.
Glenn
Old   August 19, 2004, 04:40
lingo
Hi,Glenn:
You are right.However,I need a variable file about each streamlin coming with each node.So I don't want to get a group of streamline but a streamline.So I need to know the position of each node of node number at the inlet?How could I know?
Regards lingo
Old   August 19, 2004, 09:36
Michael Bo
Create a point at the inlet [X,Y,Z] and create a streamline from that point?
Old   August 23, 2004, 05:07
pi
When you export a file with every streamlines at the inlet, they are listed one after another so you can separate them in the postprocess. Below the header youŽll get a list including all the initial positions for the group of streamlines and inmediately after something like this:
X1 Y1 z1 t1
X2 Y2 Z2 t2
Xn Yn Zn tn
which are the coordinates and time for the first streamline begining in the first initial position listed. Following will be the next streamline and so on
pi
[CFD Post] Surface streamlines not located where needed siw CFX 1 July 7, 2011 19:13
How to get Streamlines to interact.? stephen__white CFX 2 April 12, 2011 17:00
Streamlines under Moving reference frame; Spiral streamline from Tecplot aiqch Tecplot 2 October 29, 2009 23:27
Custom streamlines - only 2 velocity components bernarde STAR-CCM+ 5 August 24, 2009 07:18
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 13:33
