Home > Forums > CFX
Run CFX5 using VNC
Old   August 18, 2004, 22:26
Default Run CFX5 using VNC
KKA
Hi guys
I thought this might be interested to those who will fall to the problem I experienced couple of months a go. If you're using UNIX workstation and want to run CFX5 from your home Window based computer using VNC through DSL or Cable, then this might be helpful to you. Most at times the GUI doesn't work well with VNC. either it'll open but you see the visual your grid or wouldn't run at all. To get everything perfect then except the Solver, run each separately as ff:
% cfx5pre -gr mesa
or
% cfxpost -gr mesa
these commands will allow you full access as running it in its normal mode!!
good luck!! email me if you've any question or something is not clear to you!!
Regards!!
Thread Tools
Trackbacks are On
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
Help-Edit Run in Progress BalanceChen CFX 0 March 30, 2011 09:23
How to run and save tranisent case on Cray XD1 Leon FLUENT 0 October 3, 2006 21:59
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
Restatring run Tim CFX 2 March 3, 2006 12:54
