Home > Forums > CFX
multi- stage-pump: boundary condition
Old   August 20, 2004, 05:28
Default multi- stage-pump: boundary condition
Ben
I have got a problem with setting up the boundary condition of a multi-stage-pump: i want to simulate one stage of a pump by using translational periodic dependencies. my aim is to set up the velocity distribution of the stage-outlet as inlet-boundary condition and also to give the pressure distribution of the stage-outlet reduced by the stage-pressure-rise as inlet condition. to realize this aim i need a 'fortran user source' subroutine. can anybody help me to write this source code or does anybody know where i can get this piece of code. (database, tutorial..)
i hope anybody can help me..
Greets
Ben
Old   September 1, 2004, 09:22
Default Re: multi- stage-pump: boundary condition
Olivier Braun
Hi Ben,
you do not necessarily need a user fortran code to implement this kind of b.c. You can use a "gravity-like" source term instead of this. Imagine your pump stage working against a (very strong) gravity field only, the axis being vertical. All you have to do is to compute a pressure gradient according to your pressure rise and your axial length (translation vector of your periodicity) and introduce a corresponding momentum source term in axial direction. This should do exactly what you want. In post-processing, you will have to substract the false hydrostatic pressure field you introduced to get the real pressure back (your computed solution will have equal pressure at inlet and outlet).
Hope this helps
Olivier
Old   September 6, 2004, 02:15
Ben
hi olivier
thanks, for your explanation.. your advice solves my problem.
Ben
Thread Tools
Trackbacks are On
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 02:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
problem with boundary condition??? smn CFX 5 November 24, 2009 07:37
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
