September 1, 2004, 02:01 |
convergence in different boundary condition
hello all
I have a problem with bad convergence. This model was well solved. But i changed the outlet mass flow rate, the model's convergence was bad. So i adjusted the physical timescale, still the residual is not satisfactory. Can somebody help me?. if you need more explaination, please e-mail me. thanks in advance. |
September 1, 2004, 02:51 |
Re: convergence in different boundary condition
Try few of these:
1)solve for laminar flow, then use the solution as a start for turbulent cases. 2)start with a very small timescale and then during the iteration, increase the time scale 3)can you use 'openning' BC? HK |
September 2, 2004, 13:04 |
In addition to what HK said, you might
1.check that the mass is balanced. That correct mass flow is being specified at the outlet. 2.check different scheme too, thus either UPWIND or Blend and can then be changed to higher scheme!! Regards |
Display Modes | |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 05:05 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 02:53 |
problem with boundary condition??? | smn | CFX | 5 | November 24, 2009 06:37 |
Pressure Boundary Condition | Matt Umbel | Main CFD Forum | 0 | January 11, 2002 10:06 |
