Home > Forums > CFX
CFX-Build
Old   September 3, 2004, 10:17
Default CFX-Build
catherina
Hi I am using CFX 5.6 and when I am trying to create solid with b-rep i get the msg that there is a gap between my edges After using edge match and sew there are still large blue circles around the area problems and although there are no more edges to edit it does not want to create the solid Could somebody please give me a hint on what these blue circles mean ? Many thanks Catherina
Old   September 3, 2004, 17:44
Default Re: CFX-Build
Anurag kumar
b-reb solid is created for unique single volume i.e. there should not be any intersection or branching of surfaces. In case of complex geometries where surfaces intersect each other, not the whole geometry altogether but many different complete volumes of the geometry are selected to create the solid by b-rep. For example if a geometry consists one smaller cube, inside a bigger cube and not touching each other anywhere, we can't create solid b-rep, selecting whole geometry (both cubes together). Select each cube separately to create solid b-rep. Same is true for intersection of surfaces also. if a cylinder intersects with a sphere, take both the geometries individually to create b-rep solid (say solid 1 for sphere and solid 2 for cylinder). however, we can select whole geometry as 3-D region.
Old   September 4, 2004, 17:04
Jeff
Catherina,
I suspect your problem is with "topological congruence". This fancy term means that all matching edges have to start and end at the same points. One edge can not end in the middle of another edge (say at right angles) unless the second edge has a vertex at the intersection point. In short the edges of all surfaces have to match "exactly" the edge of all adjacent surface, including end points.
Examine your mode and see of there are edges where two surfaces meet along the unbroken edge of a third (i.e. so that the edges make a "T"). The best bet is usually to rebuild the third surface as a trimmed surface including the vertex where the first two surfaces meet.
I know this sounds confusing. It takes some getting used to.
Good Luck, Jeff
Thread Tools
Trackbacks are On
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 11:08
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 14:01
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 04:13
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
