Animation file
Old   September 7, 2004, 18:53
Default Animation file
Kevin
I am working on transient simulations using CFX 4.4 in UNIX. I want to make animation file which can be payed in Windows operating system. Right now, I am able to maek a file in .P format which only AVS tran can play.
Also, how can I control the frame rate per second ?
Any help will be appreciated.
Kev
Old   September 7, 2004, 22:57
Default Re: Animation file
Jeff
Kevin,
This was very hard to do in Visualise. I recall someone creating a script to increment the time step and write out a jpeg file for each frame (manually, this is a pain), then using a third party software to create the mpeg animation. SGI has a MovieMaker that will do this.
Alternatively, if you can get ahold of CFX-Post (CFX-5.6 or later) it will read your CFX-4 files and generate the animations from right within the interface.
Jeff
Old   September 8, 2004, 01:17
Default Re: Animation file: Thanks Jeff
Kevin
Once again, without you this group is helpless.
Kev
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
