[Sponsors] | |||||
Dear Users,
Does anyone have experience using Tetra ICEM 4.cfx to build a mesh for internal air flow in buildings? I am working on a model of an operating theatre. I am not sure if the mesh I have constructed is appropriate. What parameters are important for an adequate model? Tetra Settings: Domain Size – 3m x 6m x 3m Global Mesh Size: 0.16 m Surface Mesh Size: Walls: 0.16m – 0.08m Inlet/Outlet: 0.065 – 0.025m Prism Settings: Growth Law: exp Initial Height: 15mm Height Ratio: 1.2 Number of Layers: 5 From experimental data the velocity range is from 0.1 to 0.4 m/s. What parameters are important for an adequate model? Is the mesh density ok? Are the prism setting ok for the walls? What range of y+ values is required? Best Regards Gearóid Lydon |
You have to determine whether the mesh is adequate yourself by performing a mesh independance study. The mesh required varies job to job. What type of model are you trying to do? Steady state or transient? RANS or DES/LES? These factors will also affect your required mesh. Glenn Horrocks |
Hi Glenn,
The model is Steady State using the k-w model. For the mesh independence study, I should increase the mesh density until there are no changes in results? Are the y+ values relevant? If the model is changed to transient, will the mesh have to be less dense? Best Regards Gearóid Lydon |
The basic concept of a mesh independance check is you increase the mesh density until there are no changes in results. The y+ values are relevant. If you use the default wall functions then there is no real y+ limit, just what gives you a mesh independant solution - however you will probably want y+ to be less than 1 if you want really good accuracy for seperations. The required mesh is probably the same for transient and steady state, but computing resources usually mean you have to run a coarser mesh in transient as the computing time gets pretty long. Glenn |
Hi Glenn,
Thanks for your help. Gearóid |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [ICEM] complex 2D meshing on ICEM | kassab | ANSYS Meshing & Geometry | 25 | February 25, 2013 09:46 |
| Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 18:08 |
| [ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 10:09 |
| [ICEM] Need help in ICEM CFD Mapped Meshing | falconf16 | ANSYS Meshing & Geometry | 3 | February 19, 2010 14:21 |
| Missing tets along line when meshing with ICEM CFD | Georges P. Côté | CFX | 6 | March 23, 2006 00:34 |
