Home > Forums > CFX
Species variable
Old   September 16, 2004, 11:45
Default Species variable
RK
Hello;
Does anyone know how to obatain the species alias in CFX 4.4? Is it through GETSCA? If so what would be the syntax procedure?
For in places where temperatures are not avaiable one could use the GETADD function to get the tempearure variable where it would be available as WORK(JT+INODE-1). What is the syntax for the species variable?
Thanks in advance.
RK
Old   September 17, 2004, 09:55
Default Re: Species variable
Jeff
Mass fractions, species, and user variables are all indexed through the SCAL array. That is, each of these variables is stored sequentially within SCAL.
To find the "index" of your species in the SCAL array use:
CALL GETSCA('my species',ISPEC,CWORK)
ISPEC will be returned as the index position within SCAL.
If the SCAL array is available in your subroutine, simply access your species through SCAL(INODE,IPHASE,ISCAL).
If SCAL is not available, you can access it through the WORK array as such (assuming single phase):
CALL GETADD('MYSUBR','VAR ','SCAL ',ILEVEL,JSCAL)
then access:
WORK(JSCAL + (ISPEC-1)*NNODE + INODE-1)
to get the species at each node.
If this is not a single phase problem, you need to reference:
WORK(JSCAL + (ISCAL-1)*NNODE*NPHASE + (IPHASE-1)*NNODE + INODE-1)
Check the documentation for usage of GETADD and GETSCA.
Hope this helps, Jeff
Old   September 20, 2004, 10:21
Default Species variable: THANKS
RK
THANKS FOR YOU HELP!
RK
Thread Tools
Trackbacks are On
Modelling Biomass Combustion via Species Transport Racheal FLUENT 27 April 28, 2016 06:19
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas Main CFD Forum 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
