RESISTANCE OF SHIPS
Old   September 21, 2004, 15:05
Default RESISTANCE OF SHIPS
salman
if there is anyone, who have calculated resistance of ships through CFX, Please guide me how to do it. i have got the results of many ships, but i need precise, solutions. Furthermore, i need to know the techniques for enhancing the results.
Old   September 22, 2004, 05:57
Default Re: RESISTANCE OF SHIPS
James Date
Hi
A lot of work been done in this field. Look at the references below.
http://www.iihr.uiowa.edu/gothenburg...CC/tanker.html
http://www.na.chalmers.se/hydro/hydResearch/
http://hyperteam.kriso.re.kr/cfd.htm
www.iihr.uiowa.edu/gothenburg2000/PDF/database-paper.pdf
The VLCC test case seems to have been studied well by a number of researchers. CFX has been used in a number of studies.
Regards James
Old   September 22, 2004, 12:06
salman
Hello, james, thankx for ur help. i have already seen these sites, but what i am asking for is: the procedure in CFX PRE , how to give boundary conditions, how to give initialization, and how to predict the correct resistance, from CFX POST calculator. i have made many ships in cfx, and i have also, got some results, with free surface effects in them, but my results are not up to the standard.... so, i want guidance for the techinques in improving results, may be i am making some mistakes in CFX PRE 5.7 . Waiting for kind Reply.
Old   September 23, 2004, 07:45
James Date
Hi Salman,
Your question is not an easy one! There are many things which need to be carefully considered in order to my reasonable predictions of ship resistance, probably two PhD's worth!
A few issues that spring to mind are (In no particular order):
1) Correct inflow and far field boundary conditions and locations. 2) Inlet turbulence level specification. 3) Correct near wall grid spacing (Y+ = 30 - 500 for k-e) or (Y+ <= 1.0 for SST / k-w). 4) Have enough points within the boundary layer (greater than 10 if possible). 5) Use hexahedral mesh if possible. 6) Conduct mesh independence studies. 7) Study the convergence of the relative resistance contributions i.e. pressure drag, viscous drag and wave drag (if free surface is modelled).
There are loads more things you need to look at but these are the standard ones i'd look at first.
Probably more important than modelling the whole ship geometry straight off is to validate the CFD code you are using. Look first at its performance in solving simple flows i.e. flat plate drag and compare with measured data. Then look at pressure drag. This will give you a handle on the limitations of the CFD code with regard to the flow physics you are wishing to model around the whole ship form.
Unless you have large computing resources I doubt if you will produce any meaning full results for flows around ship hulls including wave effects.
Regards James
Viscous resistance coefficients in porous medium fpingqian FLUENT 50 June 26, 2019 01:55
Inertial Resistance and Viscous Resistance Data ravitejakatragadda FLUENT 5 May 10, 2018 04:16
Ship Wave Making Resistance Yasser CFX 8 May 27, 2017 08:28
Ship resistance tobino FLUENT 0 June 27, 2011 20:31
adapt viscous resistance based on velocity / UDF Häwimeddel FLUENT 2 April 20, 2009 10:08
