import from CFX 5.7 To ICEM CFD
Old   October 9, 2004, 01:39
Default import from CFX 5.7 To ICEM CFD
Salman
hi,
How, can i import from cfx 5.7 to ICEM CFD ? i have a model, in cfx 5.7, and i want to export into ICEM CFD. i have tried but, i con not import it.please tell me the procedure of doing it, Thanks in advance, REgards, SALMAN.
Old   October 9, 2004, 05:39
Default Re: import from CFX 5.7 To ICEM CFD
deLuther
Just use File->Import->Mesh->CFX (We use old interface of ICEM 5.0). It works...
Old   October 10, 2004, 18:20
To add to deLuther's comment, you can import a mesh but cannot import a geometry. The underlying geometry is not contained in the mesh file so it is lost.
Old   October 11, 2004, 07:21
deLuther
But someone can use Transfer mesh->facets(old interface) to make geometry from mesh(and repairing of surfaces to make curves, points...)... So it is posible remesh your domain.
Old   October 11, 2004, 08:06
Rahul
In new interface edit--facets==mesh then clicking on surface, instead of BC,(patches)then you can retain your original surfaces.
Old   October 11, 2004, 18:31
Yes, you can convert meshed faces to geometry faces, however the surface will be facetted. The original smooth surface is lost. This is not generally a problem if you wish to generate a mesh coarser than the imported mesh or if the mesh is fine enough to not be significantly facetted. Whether this is a problem depends on what you are trying to do.
Old   October 13, 2004, 07:07
freefish
I use icem 4 for cfx, it can do like that, first, form cfx5.7 you get the file of *.def then in icem you can import->mesh->cfx, you can get the mesh and solid together. try it.
Old   October 13, 2004, 13:21
salman
Thankx, for all who have given their valueable advice. The problem , here with me is sort of a tricky one, i can not mesh my model, in cfx 5.6 as its a complex model i.e a submarine, so, i want to export the model in the ICEM, and then mesh it. Please help me in exporting the model from cfx .6 to ICEM, or help me meshing the model.... regards,
Salman.
mesh from icem cfd to cfx, how? Rogerio Fernandes Brito CFX 17 April 18, 2016 03:34
How to export 2-D mesh from ICEM CFD for CFX karimakhtar ANSYS Meshing & Geometry 13 November 3, 2011 09:36
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
how to use ICEM CFD mesh in CFX MareK CFX 8 October 15, 2007 10:43
related to ICEM - CFD and CFX vvj CFX 0 September 22, 2007 08:18
