Constant guess
Old   October 19, 2004, 12:16
Default Constant guess
Mary L.
Hi All,
I am starting to use CFX but I would like to know how the constant guess (if specified) affects the progress or finall results of my simulation.
Thanks Mary
Old   October 19, 2004, 18:44
Default Re: Constant guess
Hi Mary,
Depends on the simulation. Simple simulations will converge quickly no matter what the initial guess, but more complex simulations will converge slower or not at all if the initial guess is poor.
Old   October 20, 2004, 04:36
Mary L.
Hi Glemm,
Please excuse my ignorance, is constant guess the same as initial guess? Mary L.
Old   October 20, 2004, 12:12
matej
I do still think so. The initial guess can be also not constant in space of the domain. You can set the variables in initial guess to be functions of space coordinates, or domains ... . You can keep it constant throughout the domain and set its value, or you can (in steady state) let the code set the guess for you (in this case the velocity magnitude information could be helpfull for the code to set the suitable initial timestep)
hope this helps )
Matej
Old   October 21, 2004, 05:32
Mary L.
Thanks Matej.
regards Mary L.
Chemical properties that are used in Fluent kimej FLUENT 4 August 19, 2011 11:29
Constant Volume Combustion with reactingFoam Alish1984 OpenFOAM Running, Solving & CFD 2 May 8, 2011 08:51
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Really big problems when creating own materials da Jop FLUENT 0 June 28, 2007 11:15
