November 1, 2004, 18:12 |
CFX - Parallel Problems
I've been trying to set up CFX-5 for parallel operation on Windows XP.
I've sorted out the rsh service on both my master and slave machines. I've installed/started MPICH on both machines and set the user name/account and password etc. I've tested the "rsh" service both ways on my network using the "rsh winhost cmd /c echo working" command. This works for both master and slave. However, when I come to solve I get the error message: ---------------------------------------- Warning! rsh to host node1 produces the following output before the output of the command: Terminal readThe handle is invalid. This may cause problems spawning parallel slaves, especially on Windows ---------------------------------------- Although I get this message, the run does appear to be running in parallel. Does anyone know what the problem might be? Also I have found that you have to turn off the windows firewall and any antivirus software in order for CFX to run, has anyone else noticed this? Cheers CFX User |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Core usage on CFX parallel processing | alterego | CFX | 6 | December 21, 2011 05:45 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Problems with importing ICEM-CFD mesh in CFX | signofra | CFX | 3 | March 3, 2010 10:08 |
CFX local parallel on windows XP | frank | CFX | 12 | April 24, 2008 07:26 |
