Error
Dear All, I have a small problem in importing. I have meshed a domain in ICEM4.0 and saved it as .msh file. Now when i import the .msh file in CFX 5.7 it shows the error that it is unable to import the mesh : Insufficiant memory to 3D region. I have no clue if anything is wrong in mesh !!! Anybody with idea please help. Many thanks. regards, Ashish
Re: Error
What version of ICEM you are using? ICEM4CFX? Then you must go to the output section and save in CFX5 format. You should import mesh in CFX5.7 as ICEM CFD mesh. In conventional ICEM 4.x this also can be done through output: select solver (CFX5) and write file then import as ICEM CFD mesh.
Re: Error - Still the same situation
Hi deLuther, Thanks for reply. I did the same thing earlier and also tried it after your suggestion again. But the error is same "Unable to import the mesh : Insufficiant memory to 3-d region". Dont know how to resolve it. sincerely, Ashish
Error solved !!
Hi all, I have managed to import. Thanks for suggestions. regards, ashish
