Change Phase (freezing/melting)
Old   November 20, 2004, 20:15
Default Change Phase (freezing/melting)
Denise Camarano
How I simulate a freezing/melting pure metal (99.99999%)using CFX 5.5.
Old   November 23, 2004, 08:57
Default Re: Change Phase (freezing/melting)
Phil
Try upgrading to CFX-5.7, which has a built-in 'equilibrium phase change' model. You'll need to set some momentum sources to keep the solid from moving as well.
Phil
Old   November 23, 2004, 10:06
Denise Camarano
Thanks Phil. I Will do it. Denise
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
Convergence problem with thermal phase change model under low velocity conditions pitisrisuk CFX 0 July 21, 2009 11:21
what approach for direct mixing fluids with heat transfer and phase change? hennas Main CFD Forum 0 June 9, 2009 15:44
Phase change phdsantos FLUENT 0 March 20, 2009 10:19
Solid Phase change material qiulan Siemens 0 June 5, 2006 15:30
