November 10, 2004, 07:12 |
Circular dependency (ERROR #001100279)
I have searched this forum and got a lot of messages about "ERROR #001100279" in CFX. But I have new one: ------------------------------------------------------ ERROR #001100279 has occurred in subroutine ErrAction. Message: A circular dependency was detected during gradient extrapolation. This error message may be bypassed by setting the expert parameter 'stop if gradvxb error=f'. ------------------------------------------------------- It happens when CFX try to make first iteration. Does anybody know what does it mean? I also didn't find such an expert parameter "stop if gradvxb error=f". I had tried to increase elements number, and this error message have gone. Thanks in advance, Haferbrei |
November 11, 2004, 00:42 |
Re: Circular dependency (ERROR #001100279)
Some expert parameters does not exists in pre and in cfx-solve edit - you have to add it manually i.e. type parameter name while editing file in cfx-solve.
November 15, 2004, 03:07 |
This is a very common error. You can contact you local CFX representative who should be able to help you out promptly
November 23, 2004, 12:30 |
The problem here is that you have a circular dependency which in turn has an error. What you need to do is type the parameter "if circular dependency=error stop error in(circular dependency)" That should solve your problem.
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
