Circular dependency (ERROR #001100279)
Old   November 10, 2004, 07:12
Default Circular dependency (ERROR #001100279)
Haferbrei
I have searched this forum and got a lot of messages about "ERROR #001100279" in CFX. But I have new one:
ERROR #001100279 has occurred in subroutine ErrAction.
Message: A circular dependency was detected during gradient extrapolation. This error message may be bypassed by setting the expert parameter 'stop if gradvxb error=f'.
It happens when CFX try to make first iteration.
Does anybody know what does it mean? I also didn't find such an expert parameter "stop if gradvxb error=f".
I had tried to increase elements number, and this error message have gone.
Thanks in advance,
Haferbrei
Old   November 11, 2004, 00:42
Default Re: Circular dependency (ERROR #001100279)
deLuther
Some expert parameters does not exists in pre and in cfx-solve edit - you have to add it manually i.e. type parameter name while editing file in cfx-solve.
Old   November 15, 2004, 03:07
test
This is a very common error. You can contact you local CFX representative who should be able to help you out promptly
Old   November 23, 2004, 12:30
Big Boy
The problem here is that you have a circular dependency which in turn has an error. What you need to do is type the parameter "if circular dependency=error stop error in(circular dependency)" That should solve your problem.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
