-   -   How to view Vector Plot of Secondary Flow in Post? (http://www.cfd-online.com/Forums/cfx/20836-how-view-vector-plot-secondary-flow-post.html)
dan December 2, 2004 04:01
I'm hoping to investigate the secondary flow at a particular plane of my domain. However, I can't find the variable tangential Velocity, Vtheta for the vector plot in the Post 5.7. I use the cyclindrical vel components as inlet bc. Can anyone please tell me how to look at the tangential velocity component in Post? I only find Vx, Vy, Yz.... How to view Vtheta, Vr & Vaxial? Thanks a lot, Dan.
hannah December 2, 2004 11:01
Re: How to view Vector Plot of Secondary Flow in P
I just know when you creat a vector at the plane you specify, you can choose the vector projection parrmeter(none, tangential or normal on the plane) in this vector pop-up menu. if that's what you need?
good luck
hannah
dan December 3, 2004 04:41
Thank you
Hi Hannah,
Yes. That's what I'm after.... Thanks a lot.
Tajnesaie January 12, 2010 16:56
hi
I have a project about it, until now i know that have to choose "tangential" in the vector part to viwe it? but i dont know if it is correct or not? also i want to know how much the wall can affect the secondary flow in the open channels(being small or big dimention of channel)?
Sal September 27, 2012 07:02
Dear colleagues,
I would need the tangent component of velocity along a 3D circular arc surface.
Does anyone know how to get the tangent velocity as a variable and not necessarily presented as a vector plot?
I am not sure the circumferential velocity variable calculated by the Turbo Post (in my case omega=0) can be considered as a reasonably good approximation of the tangent velocity.
Best,
Sal
ghorrocks September 27, 2012 07:42
You can define a variable in CFD-Post to be any function you like - so you can do the transformation into a tangential velocity about any axis you want. Also consider a local frame of reference, that may make things easier.
Sal September 27, 2012 09:01
Thanks Glenn for your reply!
I am aware of that - I just wanted to know whether there is an easier way of doing it :)
