-   -   cluster Xeon (http://www.cfd-online.com/Forums/cfx/20840-cluster-xeon.html)
Ivan December 3, 2004 07:56
cluster Xeon
1) What is the upper limit on number of cells if I use 6-processors cluster on Linux?
2) If the head machine is Itanium and other machines are Xeons?
Ivan December 3, 2004 07:59
Re: cluster Xeon
Sorry, in 1) I meen 6-processors Xeon cluster on Linux
Twiti December 4, 2004 09:06
Re: cluster Xeon
I think the maximum number of grid elements have more thing to do with the total amount of memory than CPU.
Glenn Horrocks December 5, 2004 17:42
Re: cluster Xeon
There is a new technical tip on the CFX community site discussing this very issue.
Ivan December 6, 2004 08:23
Re: cluster Xeon
I have not got valid license of CFX yet. :((
Ivan.
Ivan December 6, 2004 08:27
Re: cluster Xeon
Is there any difference between Xeon whith 2Mb cache and 512Kb?
Glenn Horrocks December 6, 2004 17:42
Re: cluster Xeon
Yes, in some benchmarking I have seen it appears cache size is important for solver speed. The 2Mb cache computer will run significantly faster than the 512kb one.
Ivan December 7, 2004 03:57
Re: cluster Xeon
Ok, but what about the maximum number of cells in such cases?
Glenn Horrocks December 7, 2004 17:10
Re: cluster Xeon
The maximum number of elements you can run is dependant on how much ram you have, operating system limitations and how many machines you can run in parallel. CPU cache size does not affect maximum simulation size.
