CFX5.7 in Parallel
Old   December 6, 2004, 07:31
Default CFX5.7 in Parallel
Ogbeni
I finally installed CFX5.7 and coppied my hosts.ccl file from CFX5.6, when I started CFX5.7, I choose PVM Distributed run, it started and found all the slave nodes, I also memeory usage increasing on all the nodes but to my amazement, it just hung there, nothing was been solved, after several hours I shut everyhting down, is this not the appropariate way to run in Windows XP ? Thanks
Old   December 6, 2004, 11:19
Default Re: CFX5.7 in Parallel
deLuther
Under Windows choose MPICH (Windows) - the only way to do computations as fast as linux. PVM slows down with each additional machine.
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 15:52
Cumulative continuity error large in parallel simulations xiao OpenFOAM 3 March 7, 2011 04:13
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 12:00
