ICEMCFD 5.1 -> CFX 5.7.1
Old   December 14, 2004, 16:24
Default ICEMCFD 5.1 -> CFX 5.7.1
Arkadij Gajdar
I'm totaly new to CFX.
I created a hexahedral mesh in ICEMCFD 5.1 (AI Environment). Now I need somehow to convert my mesh to CFX-5 GTM file or something CFX-Pre can read. When I select CFX5 solver in ICEMCFD and do mesh export, CFX-Pre can't read it. Why? How to do that correctly?
-a.
Old   December 14, 2004, 16:37
Default Re: ICEMCFD 5.1 -> CFX 5.7.1
There could be many causes of the problem, but a common one is that the shell and volume elements are in the same part. Shell and volume elements must be seperate parts.
Glenn
Old   December 14, 2004, 16:40
Arkadij Gajdar
Thanks for answer.
Anyway. What export format should I use in ICEMCFD? And what import format in CFX? Could you describe this in more detail?
arkadij
Old   December 15, 2004, 00:18
deLuther
In CFX you have to choose ICEM CFD format (export mesh from ICEM in CFX-5 format).
Old   December 15, 2004, 21:34
Derrek
ICEM won't write a GTM file, rather ICEM exports its own format to CFX5. In Pre, you drop down the import window, select ICEM and look for the file that you wrote.
For convenience I tend to name my files MODEL.hex. The file extension is not important.
Cheers,
Derrek
Old   December 20, 2004, 05:39
Arkadij Gajdar
Thank you all. It works great.
-A.
Old   December 25, 2004, 04:01
Abhishek
Can you please give me the complete steps that you are following to import ICEM HEXA mesh to CFX pre. I am also facing the same problem. THANKS .
AutoCAD Inventor vs. CFX (ICEMCFD) Mark Humphrey Main CFD Forum 3 January 16, 2007 19:37
amd athlon64 cpu and cfx 5.7.1 solver cmete CFX 3 October 20, 2005 22:16
USRBCS in CFX 5 (actually, 5.7.1) ATS CFX 2 August 24, 2005 12:30
Available memory is less than 2GB in CFX 5.7.1 Korsh Mik CFX 3 June 5, 2005 19:34
run Build Topology in IcemCFD 4 CFX Ahmed CFX 3 March 19, 2004 16:59
