December 6, 2004, 13:55 |
VOF Geo-Reconstruct
Hello, I was wondering if anybody knows whether CFX 5.7 has VOF geo-reconstruct model Thanks Amir
December 7, 2004, 21:53 |
Re: VOF Geo-Reconstruct
No, CFX-5 doesn't use reconstructing volume tracking ala. Hirt, Nichols, Youngs, Kothe, Rider, etc...
It uses a TVD compressive advection scheme for the volume fraction equations instead. Neale. |
December 8, 2004, 15:42 |
Thanks for the hint, I will go through the manual and read about it. Do you have any comments on the accuracy of that comparing to VOF? Thanks
December 15, 2004, 19:27 |
Reconstructing volume tracking will probably be a bit better in terms of the fidelity of the approximation because you explicitly track the interface. However significant numerical issues do arise with respect to estimating the interface normal (gradient of the volume fraction). See Rider, Kothe, etc... for more info on that. Reconstruction is very sensitve to how that is done.
For many real world applications a compressive, bounded, advection scheme does an excellent job and is much easier to maintain, extend and allow more feature matrix interactions on unstructured grids than with a reconstruction algorithm. If you run free surface calculations in CFX-5 you should start with the homogenous MPF model. If that is too diffusive for your application then try inhomogenous, which will allow the two (or more) phases to separate and keeps a sharper interface. Neale |
Is Geo reconstruct scheme available for only 2 phases? | sachinthakre | Fluent UDF and Scheme Programming | 2 | September 17, 2013 13:49 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 20:47 |
VOF - Geo Reconstruct with porous/non-porous | Amir | FLUENT | 0 | November 29, 2004 10:14 |
ATTENTION!! Validty of Fluent's VOF?? | ozgur | FLUENT | 1 | February 18, 2004 11:59 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
