Starting the CFX-solver from the command line
Old   December 29, 2004, 15:49
Default Starting the CFX-solver from the command line
Tony
Hi, everyone,
I am trying to run cfx from command line, this is my command:
cfx5solve -def R1.def -ini R1_001.res -double -batch
I can get the result, but I don't know how to make solver "interplate initial values onto Def file mesh", which is very simple in cfx-solver manager. There is a check box for this option.
Old   December 31, 2004, 07:04
Default Re: Starting the CFX-solver from the command line
James Date
I know you can re-start using the command line, but like you i have yet to find a flag in the manual which interpolates the results.
Old   January 1, 2005, 20:03
Happy New Year...
Try creating a simple text file with:
EXECUTION CONTROL:
RUN DEFINITION:
Interpolate Initial Values = Yes
END
END
Then, from the command line
cfx5solve -ccl file_above -def ....
If the name of the parameter is incorrect, take a look at an output file created from the solver manager where the interpolation was selected..
Have a happy new year..
Old   January 3, 2005, 15:59
Tony
Thanks.
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 22:33
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
How to start CFX Solver with an existing parfile lentschi CFX 3 February 20, 2011 13:31
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
