Home > Forums > CFX
momentum sink
Old   January 20, 2005, 15:19
Default momentum sink
Atit Koonsrisuk
I am trying to model the flow across a turbine in a horizontal circular tube by using momentum source. I create the thin fluid subdomain at the turbine position, then set it as the momentum source. I choose the 'general momentum source' option. I assume the power that the turbine can extract from the flow. I devide that power by (mdot)x(thickness of subdomain in the direction of source component)/(rho). I get this formula by checking the unit of the specifying value, kg.m^-2.s^-2. Then I use the minus of value obtained as the source value. However the different power before and after the subdomain is significantly less than the power value specified. In addition, I check the area averaged value of (rho x flow_area x velocity). The values are the same at the inlet and outlet of the tube, but the values in the subdomain and neiborhood planes are less than the value at the tube inlet noticeably.
Do anyone have a suggestion or example for this? Thank you very much for your kind consideration.
Atit
Thread Tools
Trackbacks are On
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Help modeling heat sink aimee FLUENT 1 June 3, 2011 14:17
Momentum source coefficient and convergence meh CFX 2 November 19, 2010 17:57
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
Nonstaggered Grids and Momentum Interpolations S. Wang Main CFD Forum 3 March 2, 2001 14:44
