Home > Forums > CFX
Simple question about material defination in CFX57
Old   January 24, 2005, 17:21
Default Simple question about material defination in CFX57
windhair
I'm working on the tutorial InjectionMixer, there need to define special condition for material water. So I modify to dynamic viscosity to expression Vist, but I change the value of thermal conductivity by mistake. This need to be change back to the default value, but I can not remember the default value. How to restore the data to the default value for the materials if it is changed by mistake. Thanks
Old   January 24, 2005, 19:49
Default Re: Simple question about material defination in C
Robin
Hi Windhair,
When you load the database, uncheck the "Load Library Data". If that doesn't work, check the MATERIALS file or create a new, dummy case and look up the defaults there.
You will only have modified the fluid properties for that simulation and will not have modified the installed defaults. So the above should work.
Regards, Robin
Old   January 25, 2005, 05:04
windhair
Thank Robin. Uncheck "load library data" works if the user specified data are real value, but is doesnt work if defined with Expression. The reload of the MATERIALS_default works well.
Old   March 1, 2005, 13:24
saumil
Thread Tools
Trackbacks are On
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 10:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 21:12
Simple Question Regarding Continuity Closure RC FLUENT 2 March 25, 2004 06:30
Simple question Robi Main CFD Forum 2 February 13, 2003 01:51
A Simple Question Thomas P. Abraham Main CFD Forum 3 September 6, 1999 18:19
