Which Fortran compiler ?
Dear Experts,
I tried to run the CFX-5.7 tutorial related to Fluid Solid Interaction in a Window machine. Which Fortran compiler is required? Regards, -Harendra |
Re: Which Fortran compiler ?
Fluid structure interaction does not require a fortran compiler. It does require an ANSYS FEA license. The fortran compiler used by CFX is discussed in the documentation in the installation notes. Glenn Horrocks |
But Tutorial 20: Fluid structure interaction and mesh deformation requires that a Fortran compiler is required for Junction Box Rouitne. For Linux it states that PortLAnd Group Compiler must be installed. I want to know what is required for Windows platform.
Thanks. |
RTFM
installation manual of CFX 5.7.1- page 34 - Requirements for Windows under Section Hardware & Software requirements. (according to the pdf manuals) matej |
I'm sure you need the compaq visual fortran compiler Ver 6.5 above(the manual says)! When I run case17.(HVAC) I use V6.6 and it's OK!
U do not require any specific compiler for CFX 5.7. But in case u r using SUB ROUTINES than u may require COMPAQ VISUL FORTRAN compiler .Also CFX is more compatible with Fortran - 77.
