February 15, 2005, 11:09 |
how to define mass flow rate in CFX-Pre
I would like to use a mass flow rate as the variable in expression list in CFX-Pre. The name of inlet plane of the domain is 'in'. I name the variable as 'mdot' then define it in the 'expressions' tab as
massFlow@in [kg s^-1] When I use the 'Evaluate' tab to evaluate 'mdot', it says that this variable is dimensionless. If I define it as massFlow@in At 'Evaluate', it pass with a very hugh number that is not the magnitude of mass flow rate. So how to define mass flow rate as the variable in CFX-Pre? Thank you very much for your consideration. Atit |
February 16, 2005, 13:45 |
Re: how to define mass flow rate in CFX-Pre
I found that
massFlow()@in work! Thank you for your attention. Atit |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Mass Flow Rate Error | jallison | FLUENT | 1 | May 16, 2011 16:22 |
in CFX, how to define a inlet condition of feedback control flow rate ? | suihenry | CFX | 12 | May 14, 2009 17:59 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
sos! How to define the flow rate of outflow BC? | zjm | FLUENT | 0 | June 4, 2004 09:12 |
