how to define mass flow rate in CFX-Pre
I would like to use a mass flow rate as the variable in expression list in CFX-Pre. The name of inlet plane of the domain is 'in'. I name the variable as 'mdot' then define it in the 'expressions' tab as
massFlow@in [kg s^-1] When I use the 'Evaluate' tab to evaluate 'mdot', it says that this variable is dimensionless. If I define it as massFlow@in At 'Evaluate', it pass with a very hugh number that is not the magnitude of mass flow rate. So how to define mass flow rate as the variable in CFX-Pre? Thank you very much for your consideration. Atit |
Re: how to define mass flow rate in CFX-Pre
I found that
massFlow()@in work! Thank you for your attention. Atit |
