Pressure as the variable in Expression in CFX-Pre
Old   February 16, 2005, 13:42
Default Pressure as the variable in Expression in CFX-Pre
Atit Koonsrisuk
Please someone suggest me how to use 'Pressure' and 'area' at a certain face inside the domain as the variable in 'Expressions' of CFX-Pre.
I would like to define one variable in 'Expressions' of CFX-Pre as the function of the pressure at one certain face of my domain. I found the name of face is F5.B1.P3 and the formula is the pressure at that face times face area. However I do not know how to define that pressure. I already tried:
Pressure@F5.B1.P3 and Pressure()@F5.B1.P3 and Pressure("F5.B1.P3") and massFlowAve(Pressure)@F5.B1.P3
but none of them is acceptable. Do anyone know how to define the pressure at certain face in 'Expressions'
In addition, Function Calculator in CFX-Post can compute 'area' at any face, so there must be 'area' as the parameter in CFX, isn't it? However I have no idea how to get 'area' to use in CFX-Pre. I have tried:
area@F5.B1.P3 and area()@F5.B1.P3
they all doesn't work. In my domain, there are some 2D regions that I specify the boundary conditions. For example, I have 'in' as the 2D region for 'Inlet' boundary condition. I have tried
area@in
CFX accept this definition, but the preprocessor does not support its evaluation in CFX-Pre. Do I have to define F5.B1.P3 as the 2D region? I think that we define 2D region for specifying boundary conditions, while this face is the face on fluid subdomain for energy source, which need not any boundary condition. So I think specify it as 2D region is not right, isn't it?
Thank you very much for your kind consideration.
Atit
Old   February 16, 2005, 13:55
Default Re: Pressure as the variable in Expression in CFX-
Juan Carlos
The callback functions within CFX-Pre and the CFX-Solver only support the use of regions that are defined as : domain, sub-domain, boundary, domain interfaces, point sources or monitor points. There is no mechanism for accessing a face that is not a boundary or a domain interface.
Can you make that region a domain interface? and treat the subdomain as a domain?
For further information, you can look at the CEL Variables, Functions and Constants section of the CFX-5.7/5.7.1 documentation.
Regards, Juan Carlos
Old   February 16, 2005, 14:09
Atit Koonsrisuk
Dear Carlos, Thank you very much for your kind answer.
I follow your suggestion by defining that face as the domain interface named 'ADin'. As I stated earlier that
area@in
do work, but
area@ADin
doesn't work. Why?
In addition, do you have idea how to use pressure, because even
Pressure@in
doesn't work
Thank you very much.
Atit
Old   February 16, 2005, 15:18
Juan Carlos
When you refer to the domain interface, you should refer to a side of it. Then, you really refer to the boundary on the side you are interest in. I think that will solve the area@ADin problem..
Second, callbacks are single value functions.. You cannot access the Pressure array on a boundary via a callback yet.. You can average, min, max the array but not access the array itself.. You may be confused with the syntax, for example area is a function not a variable with syntax area@location. Other example is areaAve(variable, like Pressure)@location.
For example, to obtain the area integral of Pressure over a surface, you do : areaInt(Pressure)@location
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 16:50
Total pressure in CFX famarcfd CFX 0 June 17, 2011 10:33
how to define pressure drop with CFX post alex CFX 0 September 20, 2007 17:31
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
