-   -   Backup from the command line (http://www.cfd-online.com/Forums/cfx/21001-backup-command-line.html)
Rui February 18, 2005 08:39
Is it possible to create backup files during a simulation (like Backup Run in CFX-Solver), from the command line? If it is, how?
Thanks and regards,
Rui
Forrest February 18, 2005 09:07
Re: Backup from the command line
under the command line (assume your are using cfx5 solver) type: cfx5control -h
you will find the necessary information to back up files.
Hope this helps, regards, Forrest
Rui February 18, 2005 10:53
Thanks a lot Forrest.
It works with: cfx5control test_001.dir -backup (if test_001.dir is the directory where the Solver is running)
By the way, do you know if there is any difference between: cfx5control test_001.dir -stop ;and: cfx5stop -directory test_001.dir
Regards,
Rui
Forrest February 18, 2005 11:04
Rui,
I don't know the the difference between them but they seem to be the same in terms of stopping a simulation.
Regards, Forrest
Rui February 18, 2005 11:11
Thanks for your help, Forrest
Regards,
Rui
Jeff February 22, 2005 00:58
I believe you can also just create an empty file (with touch) called trn in the temporary problem directory:
touch myproblem.dir/trn
Jeff
Rui February 22, 2005 11:19
I'm sorry but I didn't understand your sugestion. Do you mean inserting into the command line: touch myproblem.dir/trn ? (It doesn't work)
Could you please be more precise?
Thanks and regards,
Rui
