Backup from the command line
Old   February 18, 2005, 07:39
Default Backup from the command line
Rui
Is it possible to create backup files during a simulation (like Backup Run in CFX-Solver), from the command line? If it is, how?
Thanks and regards,
Rui
Old   February 18, 2005, 08:07
Default Re: Backup from the command line
Forrest
under the command line (assume your are using cfx5 solver) type: cfx5control -h
you will find the necessary information to back up files.
Hope this helps, regards, Forrest
Old   February 18, 2005, 09:53
Rui
Thanks a lot Forrest.
It works with: cfx5control test_001.dir -backup (if test_001.dir is the directory where the Solver is running)
By the way, do you know if there is any difference between: cfx5control test_001.dir -stop ;and: cfx5stop -directory test_001.dir
Regards,
Rui
Old   February 18, 2005, 10:04
Forrest
Rui,
I don't know the the difference between them but they seem to be the same in terms of stopping a simulation.
Regards, Forrest
Old   February 18, 2005, 10:11
Rui
Thanks for your help, Forrest
Regards,
Rui
Old   February 21, 2005, 23:58
Jeff
I believe you can also just create an empty file (with touch) called trn in the temporary problem directory:
touch myproblem.dir/trn
Jeff
Old   February 22, 2005, 10:19
Rui
I'm sorry but I didn't understand your sugestion. Do you mean inserting into the command line: touch myproblem.dir/trn ? (It doesn't work)
Could you please be more precise?
Thanks and regards,
Rui
Backup mdef simulation Daniel Leite Oliveira CFX 0 July 8, 2011 12:35
CFD Online Running on Backup Server pete Site News & Announcements 0 March 25, 2011 14:51
Backup results in steady simulation Li CFX 0 July 9, 2007 05:39
An error has occurred when Writing backup file tian CFX 0 June 28, 2007 21:29
Backup & Restart problem Sally CFX 4 November 19, 2005 12:44
