Home > Forums > CFX
CFX 5.7 solver error
Old   February 24, 2005, 23:08
Default CFX 5.7 solver error
Neser
Hi, there I got the following error in CFX5.7 solver after the program past about 4 ittrations.
'The CFX-5 solver could not be started, or exited with return code 255: . No results file has been created'
Any one know what this error means
Old   February 25, 2005, 12:33
Default Re: CFX 5.7 solver error
Rui
Are you using the moving mesh capibility? If so, take a look at: http://www.cfd-online.com/Forum/cfx.cgi?read=9363 ; and if you have access to the CFX Community web site take also a look at: http://www-waterloo.ansys.com/cfxcom...p?TOPIC_ID=629
But as Glenn Horrocks says: " the min mode el expert parameter does not work all the time ... The only totally reliable fix is to update to CFX 5.7.1 where the problem has been resolved.", so consider to update to CFX-5.7.1
Regards,
Rui
Old   February 26, 2005, 19:05
Neser
But I am already useing CFX 5.7.1.
Old   February 27, 2005, 14:05
Rui
Are you using the moving mesh capability, or aren't you? If you are, try with the expert parameter (however you shouldn't need it in CFX-5.7.1).
Regards,
Rui
Old   February 28, 2005, 12:05
Neser
I am not using moving mesh capability.
Regards
Old   February 28, 2005, 12:55
Rui
Hi Neser,
If you have access to the CFX Community web site, take a look at: http://www-waterloo.ansys.com/cfxcom...Terms=code,255 , where an error with return code 255 is reported (CFX-5.7.1). On the last post, the person who reported the error says: "it looks the problem was caused by an antivirus application which had a firewall feature in it. No problems since I disabled that."
However, as the cause of the error was not clear, as your error may be caused by something else, and as it seems you are having more errors with CFX-Solver, I think you should contact CFX technical support.
Regards,
Rui
Old   February 28, 2005, 19:50
Neser
thank you Rui, I will
Old   February 28, 2005, 23:23
Santhosh
Yes the problem was due to McAfee's buffer overflow protection mechanism. I havent faced any problems since I disabled the buffer overflow and port blocking features.
Santhosh
Old   March 1, 2005, 07:31
Neser
Hi, Santhosh
How can I disable the buffer over flow please. I am using ver 7.1.0. Non of the manues mention buffer over flow
thanks
Old   March 1, 2005, 11:59
Santhosh
Well I have the enterprise ver 8.0.0 and in that it was pretty straight forward, it was available on the virus console dialog box. Are you trying a parallel run or at what stage is this error occuring?
Regards, Santhosh
Thread Tools
Trackbacks are On
Native ParaView Reader Bugs tj22 OpenFOAM Paraview & paraFoam 270 January 4, 2016 12:39
Error in CFX Solver Leuchte CFX 5 November 6, 2010 07:12
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
user defined function cfduser CFX 0 April 29, 2006 10:58
cfx 5.7 solver error hazri CFX 1 March 2, 2005 05:14
