Home > Forums > CFX
CFX5.7.1 Solver error
Old   February 28, 2005, 12:13
Default CFX5.7.1 Solver error
Neser
In CFX5.7.1 solver after 18 itterations, a new window with titel Solver-prm.exe is appeared in the screen.
under this title, it said ' solver-pvm.exe has encountered a problem and needs to close. We are sorry for the inconvenience'.
any help from any body thanks
Old   March 3, 2005, 01:34
Default Re: CFX5.7.1 Solver error
KKA
hey
I'm not sure but what I would say is that 1.make sure that the solver licence is installed properly and the server is running. 2.check your grid for negative volumes, skewness, etc. 3.make sure you accurately and correctly defined all the parameters in the cfxpre. thus ur boundary conditions, material selection, etc. 4.the mode of running, either serial or parallel. make sure that all the "seats" have not been taken and that u've some for it. This only applies if there're more than one person using the licence. say, you only have 2 seats and 4 parallel package, and some one is running on all the 4 parallel mode, u can only run on ONE serial mode.
I hope all these will help.
regards!!
Thread Tools
Trackbacks are On
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
