Parallel with Windoze, speed difference between PV
Old   March 9, 2005, 07:43
Default Parallel with Windoze, speed difference between PV
Charles
I am running CFX 5.7.1 parallel on a mixed cluster of machines, all with Windows. The cluster consists of a dual Xeon 3.6, a quad Opteron 248 and 5 3.2 GHz P4's. Some of the tests that I have run have shown a dramatic improvement in wallclock time when going from PVM to MPI. Can anybody throw some light on this? I vaguely recall somebody once mentioning that PVM on Windows is not nearly as quick as on Linux?
Old   March 9, 2005, 16:24
Default Re: Parallel with Windoze, speed difference betwee
On windows machines MPICH for windows is usually much faster than PVM. In my benchmarking running MPICH on windows is roughly the same speed as running PVM on Linux. I have no idea why the difference, but that's the end result.
Old   March 9, 2005, 21:42
Neale
The PVM implementation really sucks on Windows and is especially bad when you run on dual Xeons. MPICH is better but is less stable.
On a quad opteron you should be seeing superlinear performance if your case is big enough (PVM or MPICH)
Old   March 10, 2005, 01:25
Charles
Thanks guys, your comments are very much in line with what I've been observing.
operation speed Difference between 32bit & 64bit IUIU FLUENT 1 February 9, 2011 22:06
Increase speed of parallel computation Purushothama Siemens 2 November 30, 2010 14:51
Parallel speed up Soren CFX 18 May 31, 2002 12:26
Parallel speed up for CFX 5 on PC's Roued CFX 6 November 28, 2001 18:02
speed up ratio at parallel processing Kim hak-gyu Main CFD Forum 1 October 25, 2000 09:57
