Home > Forums > CFX
Cannot define 2 fluids simultaneously?
Old   April 4, 2005, 07:04
Default Cannot define 2 fluids simultaneously?
Bengonia.Boom8
Hi all, I am going to simulate a fuel-oil cooler, and I find that I cannot define 2 fluids types in this analysis. For ex. I have 3 domains--solid(aluminum),fluid1(fuel),fluid2(oil), but I just cannot define two different fluid types in this analysis ! When I setup fluid1 as fuel1 then the fluid2 will be changed to fuel1, no matter what has been assigned to fluid2, and vice versa. Thanks in advance!
Old   April 4, 2005, 09:08
Default Re: Cannot define 2 fluids simultaneously?
Juan Carlos
This is not supported in the GUI, unless you set an enviroment variable before starting CFX.. There is an explanation in the thread about Different Turbulence Models in different domains..
The explanation is very good..
Good luck, JC.
Old   April 5, 2005, 06:18
Bengonia.Boom8
Hi Juan Carlos, thanks! But I cannot find the explanation you mentioned from the pdf files in CFX.
Old   April 5, 2005, 09:15
Default Sorry, I found it now. Thanks
Bengonia.Boom8
Sorry, I've found it( it's in this forum)
Thread Tools
Trackbacks are On
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 140 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
