Home > Forums > CFX
Transient - Momentum Source
Old   May 2, 2005, 11:31
Default Transient - Momentum Source
stex_
In this days I run some stationary problems in a module of heat exchanger at low Re appling a "Momentum Source" and "periodic" boundary condition for inlet-outlet.
Growing up the velocity we know that in this problems we have some non-stationary effect, so the question is: "Is it possible to define a momentum source in a "transient" simulation?"
In theory if you define a Mom.Source you specify a constant deltaP, but in a transient phenomena the delta P is variable!
In fact I tried and after some iterations the solver stopped due to very high Mach number (floatin point error)!!!
Maybe someome can help me to turn the problem...
THANKS.
Old   May 2, 2005, 18:44
Default Re: Transient - Momentum Source
Yes, it is possible to implement a transient source. I suspect your floating point error is caused by divergence in the simulation.
Regards, Glenn
Old   May 4, 2005, 09:10
stex_
Ok, but I've tryed with both constant and time-dependent values of the Mom. Source (e.g. t*100) and everytime I got the same error. The mesh is ok, because with stationary run, I got good results.
How do I have to proceed?
Thanks
Thread Tools
Trackbacks are On
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 03:40
momentum source term zwdi FLUENT 13 December 5, 2013 18:58
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 10:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 06:10
Mass transport, momentum source and turb K.E CFDtoy FLUENT 0 April 24, 2006 00:33
