-   -   Batch+Parallel+MPICH startup? (http://www.cfd-online.com/Forums/cfx/21239-batch-parallel-mpich-startup.html)
KEN May 11, 2005 00:42
Dear all, I do parallel and batch run from a batch file by setting cfx5solve -def A1.def -par-dist hostpc,client1pc,client2pc -partition 3 But it will run in PVM mode not MPICH, then how should I do to let it run in MPICH mode?
KEN May 11, 2005 02:06
I've tested ok! Thanks.
The correct setting will be: cfx5solve -def A1.def -par-dist hostpc,client1pc,client2pc -start-method "MPICH Distributed Parallel (Windows)" -partition 3
Akin May 11, 2005 08:32
Re: I've tested ok! Thanks.
How will it work if you have a result file and you want to start the simulation from where the last simulation ended ?
KEN May 11, 2005 09:54
cfx5solve -def A1.def -ini previousResult.res -par-dist hostpc,client1pc,client2pc -start-method "MPICH Distributed Parallel (Windows)" -partition 3
