Home > Forums > CFX
why H-energy ??
Old   May 13, 2005, 07:01
Default why H-energy ??
Alex
Dear experts...
I'm dooing a CHT simulation where the fluid has constant properties (air at 25C) and I've activated Boussinesq model for the buoyancy.
The flow is turbulent.
I use the thermal energy model.
So I can say : h_tot=h_stat=c_p*dT
Dooing so, I suppose that in the energy equation the pressure's work (-dP/dt) will be neglected.Isn't it ??
If I rewrite the Reynolds averaged energy equation with an eddy viscosity model I should say (eq 32 solver theory ):
rho*c_p*dT/dt+c_p*rho*div*(U*T)=div*(lambda*grad T+c_p*mu/Pr*gradT)
So I have only the temperature!
When I run my simulation I see that an H-energy equation is still solved: WHY ??
One last question...
When I activate the buoyancy the pressure in the momentum equations excludes the hydrostatic gradient. So if I have an incompressible fluid, can I say that the modified pressure due to turbulence effects (solver theory pag 67) will be as follow?
p'=p+2/3*rho*k-rho_ref*g*(r-r_ref)
where r_ref is a reference location.
Thanks you all
Alex
Old   May 13, 2005, 14:21
Default Re: why H-energy ??
Robin
Did you select Total Energy or Thermal Energy?
Old   May 13, 2005, 15:52
Alex
Hi Robin
Maybe you didn't see....no problem!
I selected Thermal Energy
Thanks
Old   May 13, 2005, 17:10
Juan Carlos
Dear Alex,
The ANSYS CFX solver always solves either the Static Enthalpy (Thermal Energy) or the Total Enthalpy (Total Energy). Your equations imply that the Specific Heat Capacity does not change throughout the domain.
In either case, H-Energy means solving for some kind of enthalpy..
Hope this clarify your concerns, Juan Carlos
Old   May 14, 2005, 05:54
Alex
Hi Juan Carlos
Thanks for your reply.
Maybe I realize ! Please correct me if I'm wrong:
in my simulation I have a constant Specific Heat Capacity and density. So the enthalpy (static because of the thermal energy model )depends only by temperature.
In any case the solver compute the enthaply,isn't it?
Thanks
Alex
Thread Tools
Trackbacks are On
energy spectra from LES simulations kumar OpenFOAM Post-Processing 2 February 23, 2016 13:25
volumetric reaction and energy balance? m.beh FLUENT 1 October 17, 2011 17:21
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 0 June 16, 2009 15:53
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
question about energy equation zhou FLUENT 0 February 24, 2004 00:55
