May 19, 2005, 14:09 |
plot: pressure-time
Hello everybody!
I am working on a twophase flow in a horizontal pipe and I'm having this problem: i have to create a plotressure-time (my simulation is transient)and everytime i am trying to make it, the programm doesn't seem to react, i mean it's doing like it's thinking but i don't get any results... i have to mention that i have already created a polyline, so as to have a locator, but it didn't bring much.what could be wrong?(the rest is ok!) thanks in advance |
May 19, 2005, 14:48 |
Re: plot: pressure-time
If you want to create a plot pressure-time in CFX Post, you have to select the Chart tab, and chose the Type: Time. Then you have 2 options: 1- You may chose the Method: Point, and chose a variable. CFX-Post will plot the time evolution of the variable at the point you selected. 2- If you chose the Method: Expression, you have to type an expression, or an expression name, and CFX-Post will plot the time evolution of that expression. Note that by doing this, the plot will only include time instants available in CFX-Post. You also have the option of creating monitor points when you define the problem in CFX-Pre, and then you may export the results from CFX-Solver which include all the timesteps. In CFX-Post you cannot create a transient plot over a polyline (this would be a 3D plot). The only way to do this is to export the results from CFX-Post at different time instants, and use Excel or Matlab, for example, for ceating the plot. Hope this helps. Regards, Rui |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
